Specify the number of challenges that you want the RADIUS SNMP server to send to authenticate a given session.
RADIUS SNMP field descriptions
Use the data in the following table to use the RADIUS SNMP tab.
 Name  |
 Description  |
 Enable  |
 Enables or disables timer authentication on the server. The default is true.  |
 AbortSessionTImer  |
 Specifies the allowable time, in seconds, before aborting the RADIUS SNMP server session (30 to 65535). The default is 180.  |
 ReAuthenticateTimer  |
 Specifies the time, in seconds, between reauthentications of the RADIUS SNMP server (30 to 65535). The default is 180.  |
 AcctEnable  |
 Enables or disables the RADIUS SNMP session timer.  |
 UserName  |
 Specifies the user name for the RADIUS SNMP accounting.  |
