Configure a prefix list to allow or deny specific route updates. A prefix list policy specifies route prefixes to match. After a match occurs, the system uses the route.
The prefix list contains a set of contiguous or noncontiguous routes. Reference prefix lists by name from within a routing policy.
Important
When you configure a prefix list for a route policy, add the prefix as a.b.c.d/32. You must enter the full 32-bit mask to exact a full match of a specific IP address.
You configure prefix lists on a VRF instance the same way you configure the GlobalRouter, except that you must use VRF Router Configuration mode.
Configure a prefix-list. Display the prefix list.
Switch> enable
Switch# configure terminal
Switch(config)# ip prefix-list LIST1 192.0.2.1/255.255.255.0
Switch(config)# show ip prefix-list LIST1
                           Prefix List - GlobalRouter
        PREFIX           MASKLEN FROM TO
List 1    LIST1:
        192.0.1.2.1     24      24   24
1 Total Prefix List entries configured
Name Appendix for Lists Converted from Old Config:
@A=conv addr list, @N=conv net list, @NR=conv net list modified as range
Variable definitions
The following table defines parameters for the ip prefix-list command.
 Variable  |
 Value  |
 {A.B.C.D/X}  |
 Specifies the IP address and the mask in one of the following formats:
 ge <0–32>  |
 Specifies the minimum length to match. Lower bound and higher bound mask lengths together can define a range of networks.  |
 id <1-2147483647>  |
 Specifies the Prefix list ID.  |
 le <0–32>  |
 Specifies the maximum length to match. Lower bound and higher bound mask lengths together can define a range of networks.  |
 name WORD<1-64>  |
 Renames the specified prefix list. The name length is 1–64 characters.  |
 WORD<1-64>  |
 Specifies the name for a new prefix list.  |
Use the data in the following table to use the show ip prefix-list command.
 Variable  |
 Value  |
 {A.B.C.D}  |
 Specifies the prefix to include in the command output.  |
 vrf WORD<1-16>  |
 Specifies the name of the VRF.  |
 vrfids WORD<0-512>  |
 Specifies the ID of the VRF and is an integer in the range of 0–512.  |
 WORD<1-64>  |
 Specifies a prefix list, by name, to use for the command output.  |
The following table defines parameters for the show ip prefix-list command output.
 Variable  |
 Value  |
 PREFIX  |
 Indicates the member of a specific prefix list.  |
 MASKLEN  |
 Indicates the prefix mask length in bits.  |
 FROM  |
 Indicates the prefix mask starting point in bits.  |
 TO  |
 Indicates the prefix mask endpoint in bits.  |
