Flush or clear the routing tables for administrative and troubleshooting purposes. The clear and flush commands perform the same function; they remove the contents of the table.
Switch:1>enable Switch:1#configure terminal Switch:1(config-if)#vlan action 123 all Switch:1(config)#clear ip route vlan 123
The following table defines parameters for the vlan action and clear ip route vlan commands.
 Variable  |
 Value  |
 <1-4059>  |
 Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1.  |
