Perform this procedure to view capabilities information for remote LLDP-MED on specific ports based on the information advertised by the remote device and received on each port in the capabilities TLV.
 - Click Port MED.
 - Click the Neighbor Capabilities tab.
Neighbor Capabilities Field Descriptions
 Name  |
 Description  |
 TimeMark  |
 Specifies the time filter. For more information about TimeFilter, see the TimeFilter textual convention in IETF RFC 2021.  |
 LocalPortNum  |
 Specifies the port on which the remote LLDP-MED information is received.  |
 Index  |
 Specifies the connection instance unique to the remote LLDP-MED.  |
 CapSupported  |
 Specifies the LLDP-MED capabilities supported on the remote system.  |
 CapCurrent  |
 Specifies the LLDP-MED capabilities that are enabled on the remote system.  |
 DeviceClass  |
 Specifies the remote LLDP-MED device class.  |
