Perform this procedure to enable and configure Energy Saver globally using the quick configuration Efficiency Mode. Efficiency Mode automatically configures the following:
enables Energy Saver on all ports.
creates a default schedule with a weekday schedule of Energy Saver activated from 6:00 p.m. to 7:30 a.m., and during weekends. You cannot change this default schedule while Efficiency Mode is enabled.
enables Energy Saver globally.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#energy-saver efficiency-mode
The following table defines parameters for the energy-saver command.
 Variable  |
 Value  |
 efficiency-mode  |
 Enables efficiency mode. The default is disabled.  |
