Displaying the VTEP next hop
Use the following procedure to display information about the remote VTEP.
 - Click VTEP.
 - Click the Next Hop tab.
Next Hop field descriptions
Use the data in the following table to use the Next Hop tab.
 Name  |
 Description  |
 VtepId  |
 Specifies an index value in the range from 1 to 500 that uniquely identifies this remote VTEP.  |
 Ip  |
 Specifies an IP address that uniquely identifies this remote VTEP tunnel.  |
 IfIndex  |
 Specifies the interface index of the next hop to reach the remote VTEP.  |
 Vid  |
 Specifies the VLAN ID of the next hop to reach remote VTEP.  |
