Use the data in the following table to use the L3 MC Redist Home Static ISID List tab.
                                 Name  |
                                 Descriptions  |
                                 Type  |
                                 Specifies the layer 3 static I-SID routed multicast redistribution type. The default type is staticisid.  |
                                 Enable  |
                                 Enables layer 3 static I-SID routed multicast redistribution in the home area. The default value is disabled.  |
                                 IsidListName  |
                            Specifies the name of the I-SID list. The default I-SID list name is htr. |
                                 Apply  |
                                 Applies the Multi-area SPB layer 3 static I-SID routed multicast redistribution filters in the home area. The default value is noAction.  |
