Use the following procedure to display information about the configuration of RADIUS dynamic session changes.
Switch:1#show radius dynamic-server
                        RADIUS Dynamic Authorization General Info
CLIENT                                   UDP        CLIENT     SECRET
ADDRESS                                  PORT       ENABLED    KEY
192.0.2.15                               1026       Disabled   ****************
192.0.2.16                               1027       Disabled   ****************
All 2 out of 2 Total Num of RADIUS Dynamic Authorization clients displayed
Display dynamic server statistics:
Switch:1#show radius dynamic-server statistics
                 RADIUS Dynamic Authorization Global Statistics
Disconnects From Invalid Client Addresses:     0
CoAs From Invalid Client Addresses:            0
The following table defines parameters for the show radius dynamic-server command.
 Variable  |
 Value  |
 client WORD<0-46>  |
 Display RADIUS Dynamic Authorization configuration values for the specified client.  |
 statistics  |
 Display statistics for RADIUS Dynamic Authorization clients.  |
