This procedure only applies to the VSP 7400 Series.
Perform this procedure to view remote IS-IS adjacency information. The platform sends IS-IS Hello (IIH) packets to discover IS-IS neighbors and establish and maintain the IS-IS adjacency. The platform continues to send IIH packets to maintain the adjacencies that the system establishes. For two nodes to form an adjacency the B-VLAN pairs for the primary B-VLAN and secondary B-VLAN must match.
  1. In the navigation pane, expand the Configuration > Fabric folders.
  2. Select IS-IS Remote.
  3. Select the Adjacency tab.
Adjacency Field Descriptions
Use the data in the following table to use the Adjacency tab.
Name
Description
Interface
Specifies the remote IS-IS interface on which the adjacency is found.
Level
Indicates the level of the remote IS-IS interface (Level 1 [default] or Level 2).
State
Specifies the state of the adjacency:
  • down
  • initializing
  • up
  • failed
LastUpTime
Indicates when the adjacency most recently entered the state up, measured in hundredths of a second since the last re-initialization of the network management subsystem. Displays 0 if the adjacency has never been in state up.
NeighPriority
Specifies the priority of the neighboring Intermediate System to transition to the Designated Intermediate System.
HoldTimer
Specifies the holding time in seconds for this adjacency. This value is based on received IS-IS Hello (IIH) PDUs and the elapsed time since receipt.
NeighSysID
Specifies the system ID of the neighboring Intermediate System.
AdjHostName
Specifies the host name listed in the LSP.
ParallelActive
Specifies if the current adjacency among all the parallel adjacencies between two nodes is active. The values are:
  • true
  • false
