Use the following procedure to configure the VXLAN Gateway source IP address.
 - Click VTEP.
 - Click the Globals tab.
 - In the SourceIp field, enter the VTEP source IP address.
 - In the Vrf field, select GlobalRouter or a VRF ID.
 - Click Apply.
Globals field descriptions
Use the data in the following table to use the Globals tab.
 Name  |
 Description  |
 SourceIp  |
 Specifies the VXLAN tunnel end point (VTEP) source IP address in an A.B.C.D format.  |
 Vrf  |
 Specifies the VRF name used for the source IP address, which you select from the drop down menu. This IP address can be on the GRT or a VRF. Note:
The VTEP source IP address must be on a loopback interface.  |
