View routes information to view the current configuration.
IPv6 host routes created for the IPv6 local interfaces do not display in the routing table.
Change the VRF instance as required to view route information on a specific VRF instance. Not all parameters are configurable on non-default VRFs.
 - Select IPv6.
 - Select the Routes tab.
Routes Field Descriptions
Use the data in the following table to use the Routes tab.
                                 Name  |
                                 Description  |
                                 Dest  |
                                 Specifies the IPv6 destination network address. The prefix value must match the PrefixLength.  |
                                 PfxLength  |
                                 Specifies the number bits you want to advertise from the prefix. The prefix value must match the value in the Dest field.  |
                                 Index  |
                                 Specifies the unique value that identifies the route among the routes to the same network layer destination.  |
                                 Interface  |
                                 Specifies the interface to which this entry applies.  |
                                 NextHop  |
                                 Specifies the IPv6 address of the next hop on this route.  |
                                 Protocol  |
                                 Specifies the routing protocol, such as OSPF.  |
                                 Metric  |
                                 Specifies the metric assigned to this interface. The default value of the metric is the reference bandwidth or ifSpeed. The value of the reference bandwidth is configured by the rcOspfv3ReferenceBandwidth object. For more information about reference bandwidth, see Globals field descriptions.  |
                                 NextHopId  |
                                 Identifier of the next-hop, hostname, or mac address.  |
                                 Age  |
                                 Specifies the number of seconds since the route was last updated or is last active.  |
                                 Type  |
                                 Specifies the type of route.  |
                                 PathType  |
                                 Specifies the type of path.  |
                                 SrcVrfId  |
                                 Specifies the source VRF instance.  |
                                 Pref  |
                                 Specifies the preference.  |
