Multicast group trace tracks the data flow path of the multicast streams.
Display the multicast group trace for an IGMP snoop-enabled
                                                  interface:
Switch:1# show ip igmp snoop-trace
                           Snoop Trace - GlobalRouter
GROUP              SOURCE             IN     IN         OUT    OUT        TYPE
ADDRESS            ADDRESS            VLAN   PORT       VLAN   PORT
233.252.0.1        192.0.2.6         500    1/1        500    1/5        ACCESS
233.252.0.10       192.0.2.7         500    1/1        500    1/10       ACCESS
The following table defines parameters for the show ip igmp snoop-trace command.
 Variable  |
 Value  |
 group {A.B.C.D}  |
 Specifies the group IP address in the format a.b.c.d.  |
 source {A.B.C.D}  |
 Specifies the source IP address in the format a.b.c.d.  |
