This procedure only applies to the VSP 7400 Series.
- Enable multicast on the boundary nodes.
 - Configure Multiprotocol Label Switching Virtual Private Network (MVPN) on the boundary nodes, for layer 3 VSN.
 - Configure the same policies as the boundary node on the peer boundary nodes.
Perform this procedure to configure IS-IS Multi-area SPB IPv4 routed multicast redistribution on a specific Virtual Router Forwarding (VRF) instance on the switch.
Configuring IS-IS Multi-area SPB IPv4 routed multicast redistribution for home to remote direction on VRF VRF1:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#router vrf VRF1
Switch:1(router-vrf)#isis multi-area ip redistribute routed-multicast home-to-remote
route-map test
enable
Switch:1(router-vrf)#show isis multi-area ip redistribute routed-multicast home-to-remote
vrf VRF1
         ISIS Multiarea Redistribute List for routed multicast - VRF VRF1
DIRECTION            ENABLE     RPOLICY
home-to-remote       TRUE       test
Switch:1(router-vrf)#exit
Switch:1(config)#isis multi-area ip apply redistribute routed-multicast home-to-remote
vrf VRF1
The following table defines parameters for the isis multi-area ip redistribute routed-multicast and the isis multi-area ip apply redistribute routed-multicast commands.
| Variable | Value |
| enable |
                                 Enables IPv4 routed multicast redistribution on the VRF instance.  |
| home-to-remote |
                                 Specifies the IPv4 routed multicast redistribution configuration for home to remote direction.  |
| remote-to-home |
                                 Specifies the IPv4 routed multicast redistribution configuration for remote to home direction.  |
| route-map WORD<1-64> |
                                 Specifies the name of the route policy.  |
| vrf WORD<1-16> |
                                 Specifies the multicast routing redistribution configuration for specific VRF instance.  |
