Enable IPv6 PIM-SM to offer multicasting services. After you enable IPv6 PIM-SM globally and on a particular interface, the MLD parameters take effect.
PIM-SM
PIM-SSM
Simplified vIST
- In the navigation pane, expand the following folders: .
 - Select IPv6 PIM.
 - Select the Globals tab.
 - Select the Enable check box.
 - Select sm (sparse mode).
 - Select Apply.
        Configure PIM Infinite Threshold Policy:
- To disable PIM, clear the Enable check box, and then click Apply.
 - Select enable, and then click Apply
 - To enable PIM, select the Enable check box, and then click Apply.
Globals field descriptions
Use the descriptions in the following table to use the Globals tab.
 Name  |
 Description  |
                                 Enable  |
                                 Enables or disables PIM.  |
 Mode  |
 Configures the mode on the routing switch: sm (Sparse Mode) or ssm (Source Specific Multicast).  |
                                 RegisterSuppTimer  |
                                 Specifies how long (in seconds) the designated router suppresses sending registers to the rendezvous point (RP). The timer starts after the designated router receives a register-stop message from the RP. The range is from 10–65535 and the default is 60 seconds.  |
                                 UniRouteChgTimeOut  |
                                 Specifies how often (in seconds) the switch polls the routing table manager for unicast routing information updates for PIM. The range is from 2–65535 and the default is 5 seconds. Important:
                                If you lower this value, it increases how often the switch polls the routing table manager. This value can affect the performance of the switch, especially if a high volume of traffic flows through the switch.  |
                                 DiscardDataTimeOut  |
                                 Specifies how long (in seconds) to discard data until the switch receives a join message from the RP. An IP multicast discard record is created after a register packet is sent, until the timer expires or the switch receives a join message. The range is from 5–65535 and the default is 60 seconds.  |
                                 StaticRP  |
                                 Enables or disables the static RP feature. You can use static RP to configure a static entry for an RP. A static RP permits communication with switches from other vendors that do not use the BSR mechanism.  |
                                 FwdCacheTimeOut  |
                                 Specifies the PIM forward cache expiry value in seconds. This value ages PIM mroutes in seconds. The range is from 10–86400 and the default value is 210. Topology and hardware conditions can affect the polling interval and cause an inactive route to remain for up to 12-15 minutes.  |
 JoinPruneInterval  |
 Specifies how long to wait (in seconds) before the PIM router sends out the next join or prune message to its upstream neighbors. The range is from 1–18724 and the default is 60 seconds.  |
                                 SptInfiniteThreshold Note: Exception: not supported on
                                        XA1400
					Series or VSP 8600
					Series.
                                 Enables or disables PIM Infinite Threshold Policy, so that multicast traffic follows the shared tree path through a Rendezvous Point (RP) instead of automatically switching over to shortest path tree (SPT). The default value is disabled, which means that multicast traffic is automatically switched over to SPT.  |
