Enable SPB-PIM Gateway on a VLAN interface.
                In the navigation pane, expand .
 - Click VLANs.
 - Click the Advanced tab.
 - In the row for the VLANs, double click the SpbPimGatewayMulticast field, and then select enable from the drop down menu.
 - Click Apply.
