Configure the system log to track all user activity on the device. The system log can send messages of up to ten syslog hosts.
System Log Field Descriptions
Use the data in the following table to use the System Log tab.
                 Name  |
                 Description  |
                 Enable  |
                 Enables or disables the syslog feature. If you select this variable, this feature sends a message to a server on a network that is configured to receive and store diagnostic messages from this device. You can configure the type of messages sent. The default is enabled.  |
                 MaxHosts  |
                 Specifies the maximum number of remote hosts considered active and can receive messages from the syslog service. The range is 0–10 and the default is 5.  |
                 OperState  |
                 Specifies the operational state of the syslog service. The default is active.  |
                 TlsMinimumVersion  |
                 Specifies the minimum version of TLS protocol supported by the syslog client.
 The default is tlsv11.  |
                 EncryptionType  |
                 Specifies the ciphers for preset version of TLS for the syslog.  |
                  Header
              Note: Exception: only supported on
                      VSP 8600
					Series.
                 Specifies the IP header in syslog packets to circuitlessIP or default.
 The default value is default.  |
