This procedure does not apply to VSP 8600 Series.
Use this task to enable fragmented ICMP packet filtering on a Segmented Management Instance.
    enable
    configure terminal
  2. Enter the configuration mode for the Management Instance:
    mgmt {clip | oob | vlan}
  3. Enable fragmented ICMP packet filtering:
    • For IPv4:
      ip icmp drop-fragments
    • For IPv6:
      ipv6 icmp drop-fragments
      The ipv6 icmp drop-fragments command does not apply to XA1400 Series.
