Verify that SSH services are enabled on the switch and display SSH configuration information to ensure that the SSH parameters are properly configured.
Display global system SSH information:
Switch:1(config)#show ssh global Total Active Sessions : 0 version : v2only port : 22 max-sessions : 4 timeout : 60 action rsa-host key : rsa-hostkeysize 2048 action dsa-host key : dsa-hostkeysize 1024 rsa-auth : true dsa-auth : true pass-auth : true keyboard-interactive-auth : false x509-auth : true x509-auth Trustpoint CA Name : x509-auth Identity Subject Name : 823 x509-auth overwrite : false x509-auth strip-domain : false x509-auth use-domain : - x509-auth revocation-check-method : OCSP sftp enable : true client enable : true enable : false authentication-type : aead-aes-128-gcm-ssh aead-aes-256-gcm-ssh hmac-sha1 hmac-sha2-256 encryption-type : 3des-cbc aead-aes-128-gcm-ssh aead-aes-256-gcm-ssh aes128-cbc aes128-ctr aes192-cbc aes192-ctr aes256-cbc aes256-ctr blowfish-cbc rijndael128-cbc rijndael192-cbc key-exchange-method : diffie-hellman-group14-sha1 diffie-hellman-group-exchange-sha256
The following table defines parameters for the show ssh command.
 Variable  |
 Value  |
 global  |
 Display global system SSH information.  |
 session  |
 Display the current session SSH information.  |
