Configure ACE source port entries to have the filter look for packets with a specific source port.
The ACL exists.
The ACE exists.
 - Click Advanced Filters (ACE/ACLs).
 - Click the ACL tab.
 - Select the appropriate ACL.
 - Click ACE.
 - Select the appropriate ACE.
 - Click Proto.
 - Click the Source Port tab.
 - Click Insert.
 - Specify the operator for the source port.
 - Specify the port number or port list to match.
 - Click Insert.
Source Port field descriptions
Use the data in the following table to use the Source Port tab.
 Name  |
 Description  |
 AclId  |
 Specifies the ACL ID.  |
 AceId  |
 Specifies the ACE ID.  |
 Port  |
 Specifies the source port (1–65535).  |
 Oper  |
 The eq and mask parameters specify an operator for a field match condition: equal to or mask. The mask operator is an implied eq on the mask bits.  |
 OperMask  |
 Specifies the mask parameter, {0-0xFFFF}.  |
