View Traceroute Results
View traceroute results to view performance-related data.
Troubleshooting using ping and traceroute is not supported on EDM. For more information, see VOSS Release Notes. As an alternative, use CLI.
  1. From the navigation pane, expand Configuration > Serviceability > Diagnostics.
  2. Click Ping/Trace Route.
  3. Click the Trace Route Control tab.
  4. Select a traceroute entry.
  5. Click Trace Route Result.
Trace Route Result Field Descriptions
Use the data in the following table to use the Trace Route Result tab.
Name
Description
OwnerIndex
Specifies the index of the owner.
TestName
Specifies the name of the test.
OperStatus
Specifies the operational status of the test. The default is disabled.
CurHopCount
Specifies the current count of hops.
CurProbeCount
Specifies the current count of probes.
IpTgtAddressType
Specifies the IP target address type
IpTgtAddr
Specifies the IP target address.
TestAttempts
Specifies the number of test attempts.
TestSuccesses
Specifies the number of successful test attempts.
LastGoodPath
Specifies the date and time when the last response is received for a probe.
