Display information about BGP peer groups.
The following table defines parameters for the show ip bgp peer-group command.
 Variable  |
 Value  |
 vrf WORD<1–16>  |
 Specifies a VRF instance by name (the string length ranges from 1–16 characters).  |
 vrfids WORD<0–512>  |
 Specifies a range of VRFs by ID number (the ID ranges from 0–512).  |
 WORD<0–1536>  |
 Specifies the name of the peer group (the string length ranges from 0–1536 characters).  |
