The following table defines parameters for the show isis spbm ip-multicast-route command.
 Variable  |
 Value  |
 all  |
 Displays all IP Multicast over Fabric Connect route information.  |
 detail  |
 Displays detailed IP Multicast over Fabric Connect route information.  |
 group {A.B.C.D} source {A.B.C.D}  |
 Displays information on the group IP address for the IP Multicast over Fabric Connect route. If you select source it will also display the source IP address.  |
 vlan <0–4084>  |
 Displays IP Multicast over Fabric Connect route information by VLAN.  |
 vrf WORD<1–16>  |
 Displays IP Multicast over Fabric Connect route information by VRF.  |
 vsn-isid <1–16777215>  |
 Displays IP Multicast over Fabric Connect route information by I-SID.  |
The following table defines parameters for the show isis spb-mcast-summary command.
 Variable  |
 Value  |
                                 count  |
                                 Displays the total number of SPB multicast entries.  |
 host-name WORD<0–255>  |
 Displays the IP Multicast over Fabric Connect summary for a given host-name.  |
 lspid <xxxx.xxxx.xxxx.xx-xx>  |
 Displays the IP Multicast over Fabric Connect summary for a given LSP ID.  |
