The following table defines parameters for the virtual-service copy-file command.
| Variable | Value |
                                 WORD<1-256>  |
                                 Specifies the source and destination file to copy. To specify a VM location, use the format <VM_name>:<VM_file_path/filename>. To specify a NOS location, use the format </file_path/filename> where the valid path can be one of the following:
