The following table defines parameters for the show isis spbm ip-multicast-route command.
 Variable  |
 Value  |
 all  |
 Displays all IP Multicast over Fabric Connect route information.  |
 detail  |
 Displays detailed IP Multicast over Fabric Connect route information.  |
 group {A.B.C.D} source {A.B.C.D} [source-beb WORD<0–255>]  |
 Displays information on the group IP address for the IP Multicast over Fabric Connect route. If you select source it will also display the source IP address. Specifies the source BEB name.  |
 vlan  |
 Displays IP Multicast over Fabric Connect route information by VLAN.  |
 vrf  |
 Displays IP Multicast over Fabric Connect route information by VRF.  |
 vsn-isid  |
 Displays IP Multicast over Fabric Connect route information by I-SID.  |
The following table defines parameters for the show isis spb-mcast-summary command.
 Variable  |
 Value  |
 count  |
                                 Displays the total number of SPB multicast entries.  |
                                 host-name  |
                                 Displays the IP Multicast over Fabric Connect summary for a given host-name.  |
                                 lspid <xxxx.xxxx.xxxx.xx-xx>  |
 Displays the IP Multicast over Fabric Connect summary for a given LSP ID.  |
