The following table defines parameters for the ipsec esp command.
| Variable | Value |
| <aes128gcm16-sha256> |
                                 Specifies the AES cipher with a 128-bit encryption key and GCM block mode.  |
| <aes256-sha256> |
                                 Specifies the AES cipher with a 256-bit encryption key and CBC block mode (for QAT performance mode).  |
| <aes256gcm16-sha256> |
                                 Specifies the AES cipher with a 256-bit encryption key and GCM block mode.  |
