The following table defines parameters for the interface vlan command.
 Variable  |
 Value  |
 <1-4059>  |
 Specifies the VLAN ID.  |
The following table defines parameters for the interface GigabitEthernet command.
 Variable  |
 Value  |
 {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}  |
 Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
The following table defines parameters for the ip address command.
 Variable  |
 Value  |
 <A.B.C.D/X>  |
 Specifies the address and mask.  |
